Previous Thread Conclusion-Drive-Motor Problems
DickDV
May 2002
Kalamazoo MI
2,324
Some time ago I tried to help Russ solve a motor bearing and motor overheating problem on a system located in Alabama. The drive was Robicon and the 400hp motor was Weg. Russ had experienced motor bearing failures and the motors were running very hot.
Russ sent me a Robicon Instruction Manual and started updating me on motor skin temperatures but, unfortunately, in the midst of this, was transferred to his employer's Ohio facility.
Since his transfer, he has informed me that Weg has taken responsibility for the motor bearing failures. The motor temperature problems were not able to be addressed fully since Russ was no longer available to make parameter changes and evaluate subsequent temperature changes.
Last week, by mutual consent, I mailed the Instruction Manual back to him and, unless further motor failures occur, I believe we can consider this a closed case.
Kind of a pity actually. This would have been a great learning experience for all of us. Especially at low speed and light fan load, these motors shouldn't have been nearly as hot as was reported.
I stated in earlier thread, about growing number of openings in the control field here is a little data to back it up...
2,346
Hello all, Recently, I tried to install Studio 5000 v34, v35, v36, but I mistakenly didn't install v34; is there a way to download this specific...
535
I'm hooking up a scale to an EWEB card on a 1756 PLC through ethernet/IP sockets, and I've run into an issue that seems to defy ladder logic. See...
2,699
Hello, I was messing around with my HMI and i decided to save some values from the previous cycles so i can see how much efficiently i was...
3,860
Hello When using "Return to Display Button" on a screen with parameters it seems to forget what parameters were passed to that screen previously...
1,648
