Printing from a PLC
ABTech
Oct 2006
Bridgend
30
Hi. I have been presented with the task of finding out a way to print from a PLC. We use Siemens PLC but as yet have not picked a PLC to use as we are still in the discussion stage of what to use. Does anyone have any experiance of printing from a PLC or is it eaiser to use a HMI and then print the screen. All help on this one would be appreciated as I have no knowledge of this application at all. Also what type of printer would be needed for this application.
Regards
Jonathan Davies
Some HMIs have USB ports that will plug right into a printer
On Ethernet look for something that can do a socket connection
For serial look at POS(Point of Service) printers
Hello ABTech;
If you are using S7-300/400 PLCs, you can set up a CP340/441 to connect to a serial RS-232 printer. Special blocks come with the parametrization software to enable connection and to set up print jobs. I remember we did it with a old dot-matrix Okidata printer; someone else I worked with told me recently he did it with a serial ink-jet printer, from HP I believe. In both cases the print jobs are triggered by PLC logic; quite starightforward, actually.
Hope this helps,
Daniel Chartier
I have done printing many times with Omron PLCs. It can be done using the built-in RS232C port in the CPU or the Serial Communication Units. You need to set proper communication parameters and use the TXD instruction or Protocol Macros. The applications were mainly Event Printing and Batch reports.
I mainly used Epson dot matrix printers (LX800, LX300 and UM series POS printers) with serial port. Their ESC/P commands can be used for text formatting like making the text bold or underligned or changing the color etc.
With the CS/CJ/CP series of PLCs it is easier because of the ASCII string processing instructions.
SVN
Setting up a Siemens touchscreen to print is a bit tricky but do-able. In my current application I use a CP-340 serial card and a S7-300 processor to print weights and suchlike during production. If your client wants a continuous paper record during production then the serial printer is definitely the way to go. If you want to print a large amount of stuff that can be consolidated onto a screen then using the touchscreen should do the job for you with minimal fuss with no coding required.
Regarding printers, I am using my card to log directly to a PC but we sometimes use a receipt printer. Most of these come with a documented interface (using ASCII characters) that is straighforward to use.
Hi all,
To print from PLC S7/300 using CP340, can we print according the available form?. Is the program writing on PLC too difficult?
Hello nguyenkuong;
You define the structure of the strings and variables of your print job in a DB. Here is what it looks like:
This is extracted from the manual "CP340 printer driver" that you can find here:
http://support.automation.siemens.com/WW/llisapi.dll?query=CP340+printing&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024
So basically, no, it is not difficult, in Siemens terms.
Hope this helps,
Daniel Chartier
Bit OT but as I remeber Mitsubishi had a function, where you can connect transistor outputs to printer port. I tested it once with relay output which looked/sound really weird
Hello there everyone,
I have been trying to get a cp340 to send data to a hp 810c printer...with no success.. This printer has a parallel port (36 pin). Does anyone know if it is at all possible to send serial data to this printer? Can the pin connections be changed on the 9 pin at the cp340 to the 36 pin connector at the printer side? Or do I need to buy a printer which specifically has a serial com port?
My data has been successfully sent to hyperterminal and so I feel confident my program is correct.
Thanks in advance.
David
See here for the pin out for Serial RS232:
http://en.wikipedia.org/wiki/Serial_port
See here for the pin out for Parallel (Centronics):
http://en.wikipedia.org/wiki/Parallel_port
Serial has one transmit and one receive channel, parallel has 8 data channels. So you cannot connect serial direct to parallel... but.... you may be able to use a serial to parallel converter. Epson used to do an add on module for a lot of their printers, you would have to check if HP do something similar. Otherwise you can have a look at these:
http://www.bb-europe.com/product.asp?SKU=232SPS2
It's an apples to bananas sort of thing ...
The problem is you need to convert from parallel to a serial format: parallel typically changes all the bits of at the same time on 9 wires while serial basically sends one bit at a time on two wires. You can google for converters that can accomplish this, I have not personally tried this.
Opps, Bryan's a faster typist.
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
153
Here is my recent experience using the Zebra AOI for printing from the PLC. Please do not ask me for my PLC or template files as they are the...
12,358
Hi Friends, I want to connect bar code printer to PLC via HMI (USB)& print bar code.What is reqd to do this as far as PLC Program is concerned...
2,494
We are trying to develop a quality control program using Delta PLC HMI DOP-B07S415. We want print simple text messages with time stamp. We...
6,010
My Application is to plot a graph on printer temp v/s time , for that i am using two array for X-axis & Y-axis,When operator give command the data...
1,388
