Printing Ladder in RSL5K
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
Hey folks, this is driving me batty! I'm trying to print a ladder program on 11x17 paper but it seems RSL5K is wrapping around the page when i print. I've tried everything to try to stop this and the only thing i can get to work is print in landscape, which i'm trying to avoid. Anybody else have this problem, and what are you folks using for your print settings?
I've attached a printout printed to pdf, oh and it's version 19.01.
I print to a PDF sized larger than the paper I plan to print to, then print the PDF to paper with the PDF print driver set to scale the PDF to the paper. This is the only way I've found to scale down the font size on 5000. Maybe you can do it on the newer versions and I'm still stuck in my old way of doing it?
Go to File - Print Options - Ladder Listing
Under Display check/uncheck options
Under Font/Color change the font size to 4.
Print away!
Wondering if anyone could help me print a the ladder from a PLC2/17 to a pdf format so I can share it with my oem who no longer has the hardware...
2,704
hello, I have to swap an S5 PLC with an FXon 40MR. But i would like to print the all of the blocks which are contined in the S5. I can view them...
2,427
Any one have any ideas on how to print out a rslodgics progam. As just hooking up a printer and hitting print did not work. When go to print prev...
1,931
If you have followed my previous posts concerning being stuck with MODSOFT, I have finally been given the opportunity to install Proworks32...
5,486
Does anyone know a trick to print ladder properly on 11x17? When I print on 11x17, the ladder is printed in huge letters and I find no way to...
3,254
