printing problem(gx developper fx)
jerrycat
May 2003
20
i,m having problem printing a ladder diagram which i have created with gx developer fx. i,m using a hp deskjet 1220c printer.
on some pages it prints part of the ladder and on some only the footer of the pages. can some helps me figure this problem out
thanks
I've had similar problems and did not fix them but found some work-around.
First update your printer driver. My troubles started with WinXP.
What I do is to print to a pdf document using Acrobat. Then I print from Acrobat and its all OK.
Make sure that you have the good paper size. From metric to imperial could cause you problem. Good choice is 2US Letter".
Hope this helps.
I think you can set it up when deciding what to print.
Uncheck the part that says 'renews page at each ladder block unit' it is on by default.
Also edit margins for more ladder per page - the presets are very big.
Hi everyone here, I'm facing a minor problem related to the WinCC Scada system which controls the desalination unit in the plant where I'm...
1,491
Hi All, I have created a Multi-User project in WinCC V7.0 and it is working fine except the report printing problem. In Server PC the report...
2,707
I have an application where I have 2 PanelView Plus 1000 HMIs that need to print to the same printer. I have a printer that works USB, but I...
8,088
I have searched the board and also the AB boards, but I can't find anything that can resolve my issue. I am using the print screen set-up on a...
4,243
Hey guys, can anyone tell me how to print out a screen in RSlogix5 so that the cross reference addresses appear below the the inputs and outputs...
2,389
