A printing problem related to WinCC
ali18
Jan 2009
egypt
Hi everyone here,
I'm facing a minor problem related to the WinCC Scada system which controls the desalination unit in the plant where I'm working,.. The operators intended to print out some screens/events (on A4 paper), but the printed paper has come out very small and located at the upper side of the page (to be more exact, it's shown as one fifth of the A4 paper),.. I've checked the printer properties, I've made sure that the standard size of the page is "A4", and then printed two separate pages of "word" and "excel" documents respectively,.. and they both are Ok,.. This way I've ensured that the problem lies in the WinCC itself, not in the printer!! so would you please give me a lending hand over this problem?? What do you suggest me to do next??
Thank you so much in advance..
Ali M.
is it a new problem? Has it worked before.? Have you replaced the printer recently?
In fact, the HP Laser printer has been working Ok,, and hasn't been replaced since a long time!!
The problem is that when I click on "Print" rectangle on the screen, the printed page sounds smaller than it should be,.. I need it to be all around the A4 paper!!
Hi All, I have created a Multi-User project in WinCC V7.0 and it is working fine except the report printing problem. In Server PC the report...
2,699
I have an application where I have 2 PanelView Plus 1000 HMIs that need to print to the same printer. I have a printer that works USB, but I...
8,073
I have searched the board and also the AB boards, but I can't find anything that can resolve my issue. I am using the print screen set-up on a...
4,219
Hey guys, can anyone tell me how to print out a screen in RSlogix5 so that the cross reference addresses appear below the the inputs and outputs...
2,378
i,m having problem printing a ladder diagram which i have created with gx developer fx. i,m using a hp deskjet 1220c printer. on some pages it...
2,530
