.PRJ File Spec Comprehensive Exhaustive LIST ???
Byron
Apr 2004
Caruthers, California
257
Greetings Everyone...
Question: Does ANYONE know of an EXHAUSTIVE LIST for the .PRJ files.
I Googled it. I searched here. Here is what I have so far:
(please correct any mistakes or add comments for any omissions)
TCP QUICKPANEL
AUTOMATION DIRECT DIRECTSOFT PLC
EXOR UniOP DESIGNER (.DPR; .PRJ; .ROM)
Something called GESE70 ???
I have several hundred of these different files and finally did a search for ALL of them, copied to a single folder, and viewed them all with QuickView Plus, and moved them to separate folders called:
PRJ PLC FILES
PRJ QUICKDESIGNER FILES
PRJ UNKNOWN FILES
PRJ EXOR UniOP
Thanks for any input...
If it's not too large 'zip' it and post it here someone will likely be able to tell you which one it is.
The old Toshiba EX series as well as the private label CH D100 series used .prj for the main project file.
I am having issues loading an older Quickpanel Model QPICTDE0000 with the .prj file that was supplied. Every time I try to import the file into...
1,703
You will find instructions here: https://ge-ip.force.com/communities/CC_Knowledge?product=QuickDesigner__c&q=convert%20to%20Proficy Should you...
1,115
Hi all , I have a hmi (Proface GP477R) containing a prj file(program) and want to create a replacement for spares. This HMI is obsolete and the...
2,058
I have an old GP370-SC41-24VP. It appears that the backlight may have failed. I do not have the .prj file to convert. I did manage to back up the...
3,577
Hi can someone help me find a way to view a .PRJ file. I do not have the screen that the file is from but i need to make an allen bradley version...
4,916
