Hi all,
I am having problem with my CPU374 where the EOK light keeps blinking slowly, with the LAN and STAT light is off.
For the Power Supply, only the PWR light is on, while OK and RUN is off.
I am currently unable to communicate with the CPU with ethernet nor using SNP cable. Even the firmware update failed.
This is the 2nd unit of CPU374 which have the same problem. Not sure what caused this.
I have tested another unit of CPU374 on the same power supply and backplane and it works fine. So the problem is with the CPU itself.
Have anyone came across the same problem before and came out with a solution?
Thanks a lot. Hope to hear from all of you soon.
