Problem during opening of Program in RS Logics 5
AB2005
Nov 2006
Lahore
318
Dear Friends,
I have been facing a problem that some time when I open the software RS logics 5 at HMI PC of a machine, and then directly press “Go Online” (without opening the program of PLC), system opens the default program and go online. But some time when I open the software and go direct online (without opening of program), a window appears and ask that no mach of program found. System asks for “Create new file” or “Upload use file”. I could not understand the logic for that. So what should I do to prevent to appear that window again?
:site:
There is no logic.
Well, in some cases, there is faulty logic.
If you have a program open, and hit "Go Online", (not "Online Now"), it tries to verify that the program checksum in the processor is the same as the open one. However, not all PLC/5 Processors support checksums, so invariably it want's you to go and locate the program file again, even though it should be smart enough to use the file and path you already have open.
It's just an annoyance, that has been around forever, and will probably stay around forever.
Maybe I read this wrong but I will say it anyway.
In addition to starting RSLogix5 you also need to open the current offline file for your PLC5. Then go online.
My Dear Colleagues,🤾 I have RS Logix 5 software in one of our machine HMI PC originally installed by machine supplier. Whenever I...
3,898
Hi; I have Weintek HMIs connected with an Ethernet network. Usually I do upload the data log files by using “ftp” command. By using my...
2,131
Hi I have two Laptops both have same Windows10. As one of our old machine still has PLC-5 for which we need RSLox-5, So I installed the...
3,292
1,104
Hi; To assign an IP to a device, I have installed BOOTP/DHCP server (by Rockwell). By following the instructions, I send IP to a connected...
5,327
