Problem FB41 PID
rikita
Apr 2015
algeria
27
hi , I'm trying to implement PID in step 7 using FB41.the FB41 is implemented in OB35. I know how to set parameters of PID also I know the inputs type, outputs type . the problem I get always max value at the output of the FB41 I dn't know why !
knowing that I set Kp=2 , Ti= 2s , Td= 500ms
taking SP = 2 and PV=1 I get at the output max value (LMN_PER=27648) where is the problem :(
Hi, I'm learning about FB41 and I have the following issue As you know, FB41 PID block has both manual mode and automatic mode. The first one is...
74
I'm using FB41 in a current projrct to control a Steam Pressure loop. During testing everything seem to be working fine until suddenly the output...
9,707
63
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
41
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
179
