problem for Motor Current in E3+
angi
Jan 2010
us
361
Hi guys
I setup the input assemble parameter as 100, to monitor the motor current in DeviceNet, and then send the current to N9 of SLC500(5/04)using instruction MOV, but the value of current was too bigger (around 300 Amps, shoud be 3 AMPs). Do I need to scale the value?
Yes, you need to scale the value, usually just by dividing by 100.
The E3+ reports Current as an Integer value in units of 1/100 or 1/10 of an ampere, so "300" = 3.00 amperes.
Different size E3+ overloads report in different units; the most common small and medium size use 1/100, and the big ones use 1/10. There's a table in the user manual about this.
I have a problem with a DC Motor of 250Kw. We try to process hot steel bars. We are using these motors with speed control in a roughing chain of...
3,165
Hi All, the problem occured when we powered on the machine only we notice that the motor is very hot before any order of rotation , after we...
947
Hi there, it is the first time I am going to setup and run Kinetix 350 servo drive and motor (TL-A120P-BJ34AA)in Studio 5000. I have done all...
3,110
Hi guys im struggling..I haven't really got much programming experience, but im trying to learn! But now i have hit a wall.. Im trying to make an...
1,464
Guys, I have a Kinetex 5700 2198-D032-ERS3 module with a VLP-B1002M-P Motor That we changed the gearbox from a 40-1 to a 60-1 because of torque...
4,966
