Axis Problem Kinetex 5700 with Rockwell Motor
Elijah58
Nov 2012
Aiken, SC
60
Guys,
I have a Kinetex 5700 2198-D032-ERS3 module with a VLP-B1002M-P Motor That we changed the gearbox from a 40-1 to a 60-1 because of torque issues.
using the same motor we changed the GB. after that I changed the ratio in the Axis to 60-1 and downloaded to PLC. Now the axis says it is not configured and I have checked everything and can't seem to figure why this is happening. When I try to autotune I get the message (Axis Not Configured) and the Safety State is Unknown (No Motion Connection). Any Ideas??
Running RS Studio v30
Thanks,
Eli
Does the drive still show that it is connected while online?
If no response at all from axis in the project it is likely you got a corrupted project. If all you did was change the ratio and download.
First double check that the part numbers match EXACTLY what is installed. Don’t assume or think you know until you physically look. AB likes Revision numbers and Revision A is totally different than Revision B. Enough to reproduce what you are seeing.
Thanks,
I'll try that.
Eli
Thanks Guys,
Found the problem, Someone had the other axis disconnected on this dual axis controller. Back to Rocking at the TESLA Gigafactory!!
Eli
I had a similar issue. My root cause was that I had a single drive in the motion group which an invalid safety network number. I regenerated the safety network number from the general tab of the module properties in the IO tree to correct the issue.
Hi, I have a big problem with an 1756-M02AE controlLogix module. I replace one of this with brand new one ( 1756-M02AE , same class and same FRM...
3,835
Hi all, I´m new in this forum and really need some expertise help. We have a machine with an tray stocker. The traystocker consist of 2 axis X...
3,867
Hai Friends, The GE FANUC PLC 90-30 series Motion Axis Control Module IC693APU302M. In the module the status LED Flickering so that machice...
7,346
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
65
Hello Experts, I'm wondering if this has been done before if possible to create an Emulate file that have motion control axis? I tried to...
151
