Servo problem, get´s a minus value on one axis
Putte76
Aug 2006
Åkersberga
Hi all,
I´m new in this forum and really need some expertise help.
We have a machine with an tray stocker.
The traystocker consist of 2 axis X and Y
We have 1 servoamplifier MR-J2S-40A connected to each axis.
The PLC used is a FX1N-60MT-DSS.
Somehow when i was on vacation the X-axis losed it´s position and got a minus value.
I tried to set the zero point again and after calibration the both axis goes to correct position, but when i start the machine the X-axis again get a minus value and only the Y-axis make a movement.
We changed servo amplifier and PLC but the result is the same
Have somebody experienced the same thing or have any ideas what can be wrong, i would be verry happy for help.
//Patrik
I'm not sure, but if this helps:
The PLC usually reads high +ve or -ve value on a wire break.
So check all your connections again.
Check the torque settings on each amplifier. The low setting can cause the weak responce of the servo. Mits. scailed it by very fanny way - max setting is actually 300%.
you need to provide more information. what is the problem?
negative value is quite common, is this what is bothering you?
you want it to be positive all the time?
or maybe motor doesn't move and do what is supposed to do?
when you say changing plc and servo amp didn't help, did you
test it with current program or one you downloaded before vacation?
do you get any errors? what does diplay on servo amp show on powerup?
can you jog? are the home sensor and it's flag still in the same position?
can you post your program?
We have an application with an Allen Bradley servo driving a rotary table. During normal operation the servo positions perfectly (within 0.001...
2,287
Hi All, the problem occured when we powered on the machine only we notice that the motor is very hot before any order of rotation , after we...
952
I have a machine I'm trying to refurbish. Currently, it won't home without intervention. It's using a 1746-L532 processor with two 1746-HSRV SLC...
1,223
Gents, I've an Allen Bradley Kinetix 6000 Sercos servo system with 2 motors on a rigid construction. Both motors have the same gear ratio to the...
2,677
Hi, I have a Little problem with the minus sign. The actual postion works fine but the send position doesn't arrive well in the drive. So, my...
1,880
