Problem on ControlNet Communication
ankurinet
Sep 2011
New Delhi
We have installed a control net network on which we have 3 nos Flex Logix controllers and 2 nos Workstations (PC).
The problem is that on one PC (Node Address-15) some parameters (Tags) (including both analog and digital) are not getting displayed in RSView32. I am unable to find the same tags in RSLinx. However on restarting the PC some parameters from them are getting displayed but still some parameters are not getting displayed.
We have checked all possible points like Topic reconfiguration (RSLinx), Node reconfiguration and tag update rate (RSView32), replacement of PCIC Card, even we replaced the PC etc. but the problem remains same.
Please provide us appropriate suggestion & solution.
The system detail is given below.
There are total 5 nodes on control net network the detail of every node is given below.
a) Node:1 FlexLogix 1788-CNC (Node Address-1)
The following IO modules are configured on this node.
IE-8 : 4 nos, OE-4 : 4 nos, IF-8: 1 nos, IRT-8 : 4 nos, IB-16 : 1 nos, OW-8 : 2 nos
b) Node:2 FlexLogix 1788-CNC (Node Address-6)
IE-8: 4 no’s, OE-4: 3 nos, IRT-8: 5 nos, IB-10 + OB-16: 1 nos
c) Node:3 FlexLogix 1788-CNC (Node Address-5)
IE-8: 2 no’s, OE-4: 3 nos, IRT-8: 1 nos, IB-16: 1 nos, OW-8: 1 nos
d) Node : 4 (Node Address-11)
PC (1784-PCIC), RSView 32
e) Node : 5 (Node Address-15)
To all, This is brownfield system modification of PLC-5/80C system, redundant processors with remote Flex I/O. The process is continuous (oil and...
1,438
Hi. I have an issue with the Control Net module 1756-CN2R that keeps generating 'Duplicate Node Detected' (DND) in random ControNet nodes in the...
2,059
I’ve mentioned bit of this before, http://www.plctalk.net/qanda/showthread.php?t=68356 Its a bit long Last year I inherited a system...
4,197
I've the following system at our plant A ControlLogix 1756-L55, with Eight 1756-CNB/D (Control Net Bridge Modules) at eight remote locations...
3,298
Hi guys I got a problem when I try to update a COntrolNet system, they use a 1756 CN2/B in the local chassis, I am going to add another 2...
3,035
