Problem related to AB Panelbuilder.
hegde10122
Aug 2004
I am supposed to write the tag which indicates the system date and time in Allen bradley's Panel Buider 600. The protocol is DF1 and the software version is 3.8. I am not getting the right tag.The internal tags related to time and date do not show the requisite date and time when the Panel builer is ONLINE. Please Help.
Which PLC addresses are you using:
SLC date: S:39/S:38/S:37 (DD/MM/YYYY)
SLC time: S:40/S:41/S:42 (HH:MM:SS)
PLC5 date: S:20/S:19/S:18 (DD/MM/YYYY)
PLC5 time: S:21/S:22/S:23 (HH:MM:SS)
ControlLogix ?
PLC.....Panel buider
The PLC that i am using is Micrologix 1200 Series C.RS Logix 500 is the software and the version is 6.2
For ML1200 the file that you have to access is the RTC.
RTC:0 is the year.
RTC:1 is the month.
RTC:2 is the day.
RTC:3 is the hour.
RTC:4 is the minute.
RTC:5 is the second.
RTC:6 is the day of the week.
RTC:7 indicates if RTC is disabled.
RTC:8 indicates if the RTC battery is low.
You need a memory module with RTC in the ML1200 !
Edit: It is possible that you have to move the RTC values to another file (i.e N7: ) in order for the PV to be able to read them !
Hi everyone here, I'm facing a minor problem related to the WinCC Scada system which controls the desalination unit in the plant where I'm...
1,479
Hi Everybody, i have my new plc program in a zip format. when trying to retrive the file in siemens step 7 project, am getting the error message...
1,930
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
20
328
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
43
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
187
