Problem starting programming properly in crimson 3.0
dbo20092011
Jun 2012
Lund
I have started using the crimson 3.0 software and I have run into problems right away when it comes to how I use my program.
I try to use the GetTabLabel function using
createdTab.GetTabLabel and the program says it doesn't recognize the function.
I have looked at the exampel where it writes
"GetTagLabel(index)".
I tried that aswell but can't figure out if the index is meant as an index from a vector the index of my tabs or what else it can be.
When i try a random small index number, all I get is an error on the display page where I insert my program (I directly insert my program
in the display page)
Not quite following you. Can you post a copy of your program?
Done with m project since a couple of days ago and been of flying why I haven't been responsive earlier.
I was just looking for a simple way to program like i was using e.g java but realized quickly that you didn't need that much programming, but rather use the tags in the right way.
Thanks anyway!
I am working on a project and I have CP6706-0001-0050 where I need to make PLC + simple VISU. It has all licenses and PLC is running fine. But...
7,194
I am using a ML1400 for a project, the problem arising is that the PLC is not powering up completely. The POWER LED and the Fault LED, both are...
10,175
Hi All, What would be the cause of heavy jerking of our crane during long travel operation? Here is the scenario; The time I issued a command...
31
11,870
we have a plc s7 300 and we faced problem the computer cannot open the program directly by clicking on icon. the program doesnot runing exept it...
1,456
I am running XP Prof SP2 and Step7 v5.4SP3 and installed PLCsim 5.3 SP1 but when I try to run it I get an error (S7 Simulation View has...
1,573
