Problem with Armorstart and 193-DNCT Commissioning
liberati
Sep 2013
Atlanta
39
I am having issues with communicating with some armorstarts that I am working with.
The part number is: 284D-FHB4P5D-10-RR
This is a 240VAC power and 120VAC control power.
My wiring for the 240VAC is correct as is the 120VAC I believe. I have 120VAC and 240VAC power to the device and am getting no fault lights.
The network light however always stays unlit. As I change the him configuration sometimes the network light will blink green then red then off and I will then get a fault light blink that goes away ( doesn't seem to correspond to an armorstart blink code.
Below is the current hookup.
I am using the 193-DNCT (him config tool) connected to a 1485G-P6N5-C (armorstart devicenet cable)
I have also hooked up a 24V external supply. +24 on red and Com on black.
I am getting no faults on the him module and I am getting no faults on the armorstart.
I have tried multiple things listed below.
1. Set armorstart to a node greater than 0 and less than 63. Set hmi to an address that is not a duplicate and set baud rate to 125K, 250K, and 500K.
2. Set armorstart to node to 99 (default factory setting) set him to 125K, 250K, 500K and used a node greater than 0 but less than 63. Have also done the same thing but set node to auto.
3. Set armorstart to node above 0 but below 63 and set him baud to auto and node to auto.
4. Set armorstart to node 99 and set him baud to auto and him node to auto.
I spoke with Rockwell reps who said that this is the correct setup but since it is the weekend they offer no support for them.
I have tried troubleshooting everything I can and am at my ends on this.
One thing is that the techs have told me I do not need a terminating resistor because I am going directly to the armorstart and there should not be any noise however I cannot find any documentation that confirms or denies this.
Any help would be appreciated.
Thanks,
Hi all, I have got a problem with ArmorStart 284 and also 280. Sometimes I have got same fault on ethernet. On EtherNet module start flashing NET...
1,389
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
169
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
41
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
183
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
