Problem with Safety signals in S7-400
M.MAZ
Feb 2011
Ahvaz
Hi
I have a Redundancy Automation sytem with cpus 417-4H Siemens. in my Plant there are safety modules. I have a problem with saferty signals. when I download my Pcs7 program to cpus, cpu in rack1 stops and when I restart it, The cpu don't read the safety signals, but cpu in rack0 read all signals and work correctly. Please help me about this problem.
in diagnostic buffer:
Event 12 of 94: Event ID 16# 75DD
Safety Program: Shutdown of a Failsafe Runtime Group active
The RTG_LOGIC DB 3191 detected a failure in a F Runtime group
Internal Error ID 1: 0
Internal Error ID 2: 0
Internal error, Incoming event
12:33:56:569 am 01/01/94
Event 13 of 94: Event ID 16# 75DE
Safety Program: Full Shutdown of the F-Program active
Event 14 of 94: Event ID 16# 75E1
Safety Program: Error in the F_TESTC Detected
Runtime group with the failed F-FB will be disabled.
Instance DB number of F-FB with failure: 3188
Internal Error ID 1: 12
12:33:56:351 am 01/01/94
also full diagnostic buffer messages is attached.
Thanks a lot.
Hi, I'm facing problem with AB GuardMaster Safety Relay (MSR-125HP 440R-D23171). I'm working on a project that has Safety Catagory-3 Door Lock...
2,097
Hello, I have started working in one automotive manufacturing company and we are using AB plc here. I am keep getting this problem recently that...
2,694
I'm trying to add a safety generic module for a robot CIP. Anyhow, everything is grayed out and not allowing me to add IP address or change...
1,916
Hi, I have installed Kinetix 350 and Omron safety contorller(G9SP-N20S) and wired 2 of safety output signals from Omron safety to Kinetix 350...
4,451
Hi all Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and...
4,400
