Problem with servo controller OMRON
HUGO28
Mar 2005
Hello
I have a problem with servo control from OMRON model this controler is OMRON R88D-UA20H. And :
1. I need software for this controler.
2. I need diagram with cable or interface for this controler.
If any body have any information please send me
Thanks and Best regards for As
Andy
Hi was just haveing a browse and came accross your problem and reconised the servo number! i had some issues on a servo drive due to water! and i found all the info i needed on the omron web site where there is a download section for all there manuals etc...and a couple of good websites i always relie on for info are juneusa_links and motionNet.com . Hope these will be of some help
Hi, I have a Little problem with the minus sign. The actual postion works fine but the send position doesn't arrive well in the drive. So, my...
1,885
We have an application with an Allen Bradley servo driving a rotary table. During normal operation the servo positions perfectly (within 0.001...
2,299
Hi All, the problem occured when we powered on the machine only we notice that the motor is very hot before any order of rotation , after we...
956
I have a machine I'm trying to refurbish. Currently, it won't home without intervention. It's using a 1746-L532 processor with two 1746-HSRV SLC...
1,224
Gents, I've an Allen Bradley Kinetix 6000 Sercos servo system with 2 motors on a rigid construction. Both motors have the same gear ratio to the...
2,678
