Problem with Simatic PC Adapter USB A2
nacoolp
Jun 2015
Ahmedabad
Hello there,
I also bought PC Adapter USB A2 recently. I am using Windows XP SP3. I need to connect Simatic Manager with the same.
Now the problem arises is that I am not able to install Simatic Device drivers in my PC. Thereby I am able to see PC USB Adapter A2 in the Add/Remove interfaces section in PG/PC interface. But not able to install the same. Installing the setup of the drivers, processes up to a dialog box of "Microsoft Visual C++ 2005 redistributable" which stops at their and completion window appears which shows adapter is successfully installed. On restarting cannot find the drivers of the cable and the condition persists. Attached images for the reference.
The strange thing that is happening is that using the same CD, I am able to install the drivers and work with Simatic manager properly on another PC with same OS.
On studying the matter, found out that I should run the setup as an administrator. So tried to do the same and even disabled my computer's firewall protection and antivirus as well. But the situation remains as it is.
I am confused :confused: that what might be the problem. Kindly help me with the same.
Thanks in advance
Could you try...disconect your adapter USB MPI ....then U will install the driver ..after that you will reconnect your hardware !
Dear nguyenxuanphu,
Thnx for the reply. Have tried in both the ways i.e. with adapter connected and disconnected as well. But the condition is as it is. Still cannot install the drivers.
This thread is reaction to another two: https://support.industry.siemens.com/tf/ww/en/posts/inout-parameter-problem/260345...
2,123
Dear All, I have a problem with the Simatic Timer. I'm writing a program to check the pulse signal input, if the input signal is keep changing...
2,843
Hello everyone , I have an engineering station with step7 program. I can make the modifications from this PC for 7 PLCs. But now I can not...
1,927
Hi Guys I Work in project using Wincc Comfort (wincc 7.0) and simatic manager I use siamatic simulator to test my work ,everything going ok but...
2,460
Hi Experts, We have a problem here with the Simatic S5 CPU 928B which doesnt go into RUN mode. Machine was not in use for over a year and my...
21
7,443
