Problem with Temposonic/Servo oscillations
This is starting to sound more like a physical problem.
Is there anything unique about that cylinders position?
Is it the last cylinder on a long manifold?
Maybe you have a fluid supply flow issue. It could be as simple as a piece of debris stuck in a fitting that is restricting flow. The cold fluid starves the cylinder and the oscillation is the logic compesating for the lag in response.
Once the fluid warms up, it flows past the restriction easier.
This could also explain why changing the servo control valve temporarily fixes it..... how you ask?
The new valve may be tight and can not respond quickly so it can not produce the oscillation.
Once it breaks-in, it can react faster, and you see the movement.
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
55
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
78
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
79
23
594
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
72
