Problem with updating clock in A/B PLC-5/30
chipmoseley
Apr 2014
South Carolina
I am trying to dynamically update the running PLC clock in a A/B PLC-5/30 to keep it synched with a controlling time from a master computer. I have the same program running in three different PLC5's but the clock only updates in two of the PLC's. When I move values into S:18 thru S:23, the clock does not actually change. Does anyone know anything that will prevent the clock from updating?
I've never had a problem setting the time in a PLC-5, but you might want to look at Properties for your S2 data file on that particular processor and verify that the file is not write protected.
Good thought. Nothing else on line (or connected) with this processor. Processor was isolated to a stand-alone condition. The "move" seems like it functions but there is no visible data change in the clock.
Can you post the program? Its .RSP file, zip it first.
Yeah. That is what I am thinking too. I have checked the normal data table write protection. I have checked S:2/15 and S:26/6 and they are clear. Not sure what other protection there might be to data table write or Status File writes.
If you want to attempt a brute force patch, then try writing your time data to words in a different Integer Data File and then move that data to the System clock words in your PLC program logic.
Yup, that is exactly what I am trying to do. The data transfer seems to work (and it does work on my other processors) it just doesn't record. Feels like it is being access blocked but I can't find any block.
Hey there.
Have you actually cross referenced the bits S:2/15 and S:26/6 to make sure there is nothing in your program writing to those addresses. It does not have to be another device over writing the addresses but something in your own logic.
Juat a suggestion!
Hi I am using Wonderware Intouch 7.1 and have been for quite a while. Recently I have been having problems with my application after installing...
3,999
I've downloaded firmware version 2.3 from Unity OS CD to PLC Premium 2634 using OSLoader and now it's Ethernet port is in an Error mode. What...
2,181
Using an ab slc 5/03... plant suffered some sort of power loss.. what we're seeing is the analog card (typical ab slc analog input card) is not...
6,452
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
149
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
64
