problem with wago 750-843 and I am responsible!!!!
unclehamid
Feb 2007
shiraz
79
we have several wago 750-843 ethernet(with 750-455 AI4) are connected via intranet to a PC server .all of them just feed IP with bootP software.there is no programming or hardware config with codsys.they send data (AI) to server but sometimes some stations dosn't send data (but we can ping them and we can see them by Internet Explorer )
send me the software and i will have a look at it.
the PC asks for some data and the plc should sent them, however this sometimes takes a while.
ping is hardware and just looks if ip address is active, not if plc is running.
they all should have their own address and the first three bytes should be the same for all pc and plc.
please use markers for the data as the inputs are scanned and invisible.
thank you shooter for your attention,because of high pollution here we have 2 days off + 2 days Iranian weekend(thursday & friday) we have a long holiday
after that I will send u program its based on oracle software .I hope u can check it but for wagos we don't have any program.
I appreciate your kind attitude again.
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
355
Hi guys, I've recently bought Wago 750-833 from a second-hand seller and I have quite a problem with it. When i'm trying to login i obtain...
11,614
Hi, i have some question about wago 750-841. First: memory setting. In my software use allocate memory and not allocate memory. I want about...
4,511
Hello everyone, I am trying to put WAGO PFC 200 (750-8212) in Run mode but I am getting message "The project requires software license, ...". Has...
2,382
Hello, I'm experiencing a problem with my project regarding the communication between a RENU FP5070TN-E HMI Touch Panel and WAGO I/O-IPC...
4,720
