Problem with WinCC OPC Updates
RollingPin
Feb 2008
Bangalore
36
I am using WinCC Ver 7.0 SP1 HF1 as an OPC Client with a Novotek OPC Server.
When I start WinCC and open a certain screen, all values on the screen are available and updated. If I go to another screen and come back to this screen, the tags have zero values. At that time, the status of the tags in the WinCC Tag database shows a value of '0' and quality code '4C' (initial value). At the same time, when I use Matrikon OPC browser and look at the rag values in the OPC Server, the tags have 'Good' quality and show the correct value. Now if any tag changes value in the PLC, it immediately gets updated in WinCC and the tag quality changes back to 'Good' in the tag database. If we stop the OPC server and start it again, the tags again have 'Good' quality in WinCC till we change screens. If we change screens, the quality goes back to 'Initial value'.
Anybody faced a similar problem and knows a workaround?
Exactly this problem
Hi
I have exactly this problem.
Presuming that you solved it as it is years ago, would you please be able to help me?
Regards Joe
We migrated a project from WinCC V 7.0 ( Windows XP) to WinCC V 7.5 (Windows 10).Every things okey .When the language translation button is...
422
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,293
Hello During Compiling of WinCC Flexible Project It gives me following Error Internal error(Detail: cannot get parent folder-object type:VAR)...
1,692
Hi everyone here, I'm facing a minor problem related to the WinCC Scada system which controls the desalination unit in the plant where I'm...
1,478
Dear colleagues Actually, I have a problem with the communication in WINCC. we are developing a filling station for the lab for the students. we...
4,234
