Problems using DF1 protocol
saucekorn69
Mar 2005
Quebec
27
Hi everyone,
First I would like to thank you, this forum is very helpfull, I'm glad to become a member.
I'm trying to make a Driver using the DF1 protocol, in order to ba able to communicate with Allen Bradley PlC (SlC500, Micrologix 1000).I'm developing under Visual Basic.Net using RS232 communication.
I'm currently reading the DF1 protocol, but I can't resolve some problems. I can create handle to the COM Port, but I can't communicate with the PLC, and I didn't find anywhere in the protocol what do I have to do to start communication.
If someone knows something that can help me, that would be great !
Thanks !!
Nicolas.
Ok, thanks but I already had it....
The dll might be helpfull but unfortunately it doesn't help me :(
I'm just about to finish my studies in computer software, and it's the first time I have to make a driver like this . I think Iunderstand the protocol, but I just don't know what do I have to do to start the communicating with the Allen bradley PLC which is a DH485 link by the way.
Nicolas.
If you are trying to communicate with a SLC via DH-485, that is the driver you should be developing, not DF1. When you try to communicate with your PLC, are you connecting to a DB-9 serial port on the SLC (if available) or to an RJ-45 connector?
I think I said something wrong, I'm trying to develop a DF1 driver and I'm connected to the PLC throw a RS232 cable.
Basically, I send a message, following the DF1 protocol, but It doesn't seem to work, I mean the number of bytes sent is always 0, and I cannot read neither.
Do I have to specify the node address ? According to the document, it can be a problem, the PLC just seems to ignore my packets.
Ok, i found my problem... I was using AxMSComm object, and it seems to be the problem.. I still don't know why I cannot communicate using this object otherwise I am able to send and receive data using API function.
Thank you helping me !!!
Nicolas.
For my first time, I put a copy of Studio 5000 and Factory Talk Activation Manager on my customer's machine (On-logic Windows PC), then use remote...
2,510
Was just wondering because I seen a PLC program that uses the same coil like 15 or more different rungs. The software said that malfunctions can...
1,979
Hello everyone, I have some problems regarding using the Schneider PLC USB driver within a virtual machine. I am currently using VMware...
2,112
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,431
Hi all, Is there any reason why I can't use a STAT variable in the variable declaration table in a Function Block as a one-shot? I know why...
1,481
