USB Driver problems when using virtual machine
TheSneeze
Apr 2017
Karlskoga
Hello everyone,
I have some problems regarding using the Schneider PLC USB driver within a virtual machine.
I am currently using VMware Workstation 15 Player running a Windows 7 virtual machine. When connecting the USB-cable to the virtual machine the driver appears to work the same as when connecting to the host. However, when trying to test the connection using Driver Manager the virtual port within the guest is not found.
Has anybody else had this issue, and is it fixable? I seem to recall hearing about people getting it to work but I don't know what to do.
get into your VMWare Options and allow it access to that USB device. Some have to be specifically authorized to pass through into the VM. My DeltaV key was that way.
Hi guys I bought a USB-UART bridge to communicate with OMRON CPM1A PLC. When I installed it first time with driver etc, everything was working...
3,697
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling...
609
Hi I need PC Adapter USB Driver for windows 7 32bit. How can I download it?
1,191
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,493
Hi all, I have just upgraded to windows 11 and can not connect to a Q series PLC using my USB lead which has worked for years on my windows 10...
2,527
