RSLinx Freezes Using USB Driver
patrickmoneyy
Jan 2023
TN
25
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling autobrowse made it to where it only freezes when I click on the device in the VBP or USB driver. As soon as I unplug from the device my rslinx unfreezes
So far I have tried deleting the VBP driver and restarting my computer and it had no effect.
I have observed the same behavior on a L71, L24, and a EN2DNR.
Rslinx classic lite V4.31
Windows 10 Pro for Workstations build 22H2
Dell Precision 7550
My other workstation running rslinx classic lite 4.20 freezes for about 10 seconds when I click on the device under the USB driver, but behaves normally using the VBP driver.
I just want my main workstation to have a usable USB driver. I've managed to not use it for two years because my bootp (thankfully) works consistently, but I like to have options.
Any suggestions would be appreciated 🙏
Did you try using a different USB cable?
Is this a laptop? if so, can you try using a USB hub with external power, in case the laptop does not supply enough power.
I always try to rule out the physical layer first. Good luck.
Figured it out. Deleted those notorious harmony files and now it works flawlessly without freezing. Should've figured it would be the common problem, I just couldn't find these exact symptoms cited.
Hi all, Old XP's upgraded to Win10 Enterprise LTSC. Old InTouch 10.0 upgraded to 2020 R2 SP1. 1 PC has RSLINX gateway all the others RSLINX OEM...
2,192
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
195
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
158
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
91
