produced and consumed tags RS5000
dgreen8281
Jan 2007
dayton ohio
I am fairly new to Controllogix and RS5000. I have seen programs where they use produced and consumed tags. It seems that this would be easier than using messages but I do not understand how to get the configuration into the menu. Does the PC need to be attached to the network? I tried reading all I could in AB tech site but cannot find a way. Any help appreciated.
You need to set the path for what protocol you are going to use produce consume tags. If it's an ENBT card add the other ENBT card of the rack you want to connect to in your I/O config. Then add in the remote rack's PLC (slot # and name) CNet is a bit harder in that you have to set up the controlnet nodes and then schedule the tags you are produce/consuming with RSNetworx. Do a search in this forum. There are lots of good examples on how to set this up.
BTW I see that I am local to you.
Here's a simple example of 2 plc's connected by ENBT cards
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
166
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
476
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,814
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,242
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,431
