Profibus Between siemens PLC and premium PLC
Nov 2013
ahwaz
24
Greetings
Can the Profibus network ، Schneider Premium PLC with TSXPBY100 Module was selected as Slave?
I'm going SIEMENS PLC (S7-400) as master and Schneider PLC as Slave
tanks
I aslo don't know much about this stuff but i have google
The Premium PLC not have any Profibus DP Slave except Profibus DP Master,
www automation siemens.com/WW/forum/guests/PostShow.aspx?PageIndex=1&PostID=330051&Language=en
Siemens PLCs can work as dp-master / dp-slave.
I am interfacing KS800-DP modules (temperature controller made by PMA) with SIEMENS S7-317 2DP CPU, using PROFIBUS DP Communication. The GSD file...
3,145
Hi everybody, An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on...
9,147
Greetings to all! I am newbie in profibus but i want to learn and i am free to ask on this forum for several things. I have two Siemens PLCs...
3,759
Hello, I have a question. Is it possible to set up communication between a Allen Bradley PLC and a Siemens PLC through profibus. It's because...
10,743
does any one have the experience with profibus dp communications between S5(use IM308C , as DP master) and S7-315-2dp(as slaves)? I would like to...
10,103
