SIEMENS Profibus dp between s5 and s7
StanleyZhou
Jul 2002
Ontario
22
does any one have the experience with profibus dp communications between S5(use IM308C , as DP master) and S7-315-2dp(as slaves)?
I would like to have a talk with this topic with you.
thanks
I am currently doing a project that is S5-155 944b to an S7-318dp through a IM-308c. How can I be of service?
Hi, Lenny, do you use the cpu 318 as the master or use the im308c as the master?
as I know, you need a siemens PG to download the configuration of the IM308c, you need the software COM PROFIBUS V3.3 OR higher.
I think that if the cpu318 as the master, then it should be more easier to set up the communication.but what I am going to do is use the IM308C as a Master and two cpu315-2dp as the slaves.
Stanly,
I'm using the 318 as a master. My task is to make the S7 controller use existing 115 I/O. There are 8 racks of 115 I/O that are almost fully populated with cards. It turned out that I could not address all the racks in DP format due to the routing overhead in DP. So I am using FB192 (a standard siemens S5 block) to map all the I/O into data blocks and they are read by and written to by the 308.
It is a bit confusing doing it like this in that there is a master/slave setup in the 308 program. Siemens calls it a "Default Host". I think with the 308 as master this goes away and the configuration shows master and slaves.
Yes you need to have the S7 software, S5 software and Com Profibus software. I had a lot of trouble with the Com Profibus stuff. It took some patches from siemens to make it run politely in Windows 2K pro.
Lenny
Greetings Can the Profibus network ، Schneider Premium PLC with TSXPBY100 Module was selected as Slave? I'm going SIEMENS PLC (S7-400) as master...
2,357
I am interfacing KS800-DP modules (temperature controller made by PMA) with SIEMENS S7-317 2DP CPU, using PROFIBUS DP Communication. The GSD file...
3,151
Hi everybody, An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on...
9,150
Greetings to all! I am newbie in profibus but i want to learn and i am free to ask on this forum for several things. I have two Siemens PLCs...
3,759
Hello, I have a question. Is it possible to set up communication between a Allen Bradley PLC and a Siemens PLC through profibus. It's because...
10,749
