Profibus Drivers for Zenon
Nov 2012
Pretoria
Good day all,
I hope you are doing well. I have a problem and I am wondering if you can help me sort this out.
I am using Zenon for my SCADA on a VIPA 605-1BC00 panel and I have to communicate with a VIPA PLC via profibus. Which driver should I use in Zenon for profibus in the list of drivers for them to communicate? I really got stuck and don't know which one to use. Can you please assist me?
Thanks,
Sonia
I believe it is this one.
S7 driver Softnet based (Win)
Driver for S7 PLCs via MPI / H1 / Profibus DP / TCP/IP. Based on the software SIMATIC NET (Softnet) from Siemens. (www.siemens.com)
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
190
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
322
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
318
