Profibus PA software app for field instrument monitor/configuration?
danw
Oct 2004
midwest, USA
3,428
A link provided by Dchartier in the "Shielding and grounding of Profibus" thread pointed to ProfiCoach software app that is a Profibus PA master when used with a communciations card. Interesting approach for monitoring a DP highway.
Questions:
1) Is there a similar free or inexpensive app for Profibus DP devices, that would be a master to view performance of and also configure DP devices?
Something like Siemens PDM, which we use with a HART modem (for HART devices), but which talks Profibus?
2) Is the CP5512 card a PCI card for a desktop?
Are there USB comm cards for laptops ?
Dan
hey buddy
Q1:- There is a piece of software called "Profitrace 2" which connects to the PA coupler via the proficore module (supplied)and can give extensive diagnostics about the connected loop.
I believe this module here in UK is about £3000. and is mainly used for diagnostics and can mimic a master on the bus using Proficaptain.
Other than that we just use PDM for device diagnostics configuration.
hope this helps
"Anybus NetTool" from HMS company, is a profibus-dp configuration software, that accepts any GSD files for masters and slaves. Anyone can advise...
1,693
Hey all Can I get profibus layout diagram in a nice diagram so I could troubleshoot the network. I have seen this in rsnetworx. Does any one know...
2,460
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
95
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
115
