Getting Profibus network layout diagram any software??
bornwild
May 2010
Riyadh
429
Hey all
Can I get profibus layout diagram in a nice diagram so I could troubleshoot the network. I have seen this in rsnetworx. Does any one know a software. Please advice
I think a problem maybe that the cable doesnt run in node order so a diagram of nodes would need the physical cable shown correctly to be much use
There is a physical layout and a logical layout.
Most of my experience with Profibus has been on S7, which generates a nice logical layout of the bus. This is not the physical layout, which is what I think you need.
The physical layout is generally found in the installation electrical drawings. However, some suppliers are known to not bother with these, so you may have to trace out your own drawings if these were not supplied.
there are profibus diagnostic tools which can do this for you. It calculates the network layout for you quite accurately provided there is not too much electrical noise in your profibus network.
It cannot create a layout or bus diagram if there is a repeater in between though... You can check our www.procentec.com or www.softing.com.
I use the profitrace from procentec and it is quite good...
HI ALL iwant to any thing or manual to illustrate the profibus network in S7 PLC. 1- HOW CAN I CONFIGURE THE NETWORK? 2- HOW CAN DETERMINE...
2,830
Hello, I have a S7-300 PLC I want to get online with and take an upload of the prog. I have a laptop with the correct software and USB adapter...
1,553
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
58
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
87
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
618
