Profibus Parity error
y3638
May 2012
london
Hello All,
I'm new to the site and have a question regarding a profibus error which i am hoping someone can help with
We have been experiencing a fieldbus error on one of our profibus networks.
We have profitrace connected and have setup message record triggers.
We had a fault this morning and when we checked we had the following information.
Parity error illegal 2>60 data length = 10
Data = 68 04 04 68 02 3C 08 03 49 96
I am assuming the parity error occurred on slave 60
If anyone can shed any light on what the parity error is and what the data string represents i would be very gratefull.
Many thanks,
Kev
Hi, and welcome to the forum!
I rarely use the Profitrace, but it would be easier to help if you could post a curve picture from the Profitrace o-scope.
Kalle
Edit: And where is the node 60 situated on the bus?
Edit2: A quick and perhaps dirty fix would be to shift from standard DP to user defined bus parameters. Increase the retry limit to f.x. 10.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
93
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
114
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
326
