Profibus Setup SST-PFB-CLX
djpalaz
Jan 2007
Montreal
57
Hello,
How do you configure a SST-PFB-CLX to exchange data to a slave device that has only a DPV0 operating mode. I can see the device through the SST Configuration tool. The Cyclical Data type matches for both the master and the slave. The address of the slave is set.
Hello Everyone! I am looking for a solution for making successful Profibus Communication between ABB 800XA & HOneywell HC90. I had gone through...
2,105
I have 4 seimens micromaster drive that are link by profibus. They are part of a whole MCC system. The problem is when one faults then they all...
2,340
i have two pc's with simatic wincc as HMI.i want to connect both to single s7-300 station(PLC).both pc's are about 200m from PLC. what type of...
2,265
Hi, was wondering if you could help. I have a slave module ET200 with 6ES7 331 7TF01 0AB0 AI module on Profibus that I am trying to set up. If the...
2,069
Hi I am trying to setup a profibus connection between a Siemens S7-314-2DP plc and a Siemens TP170B touch panel. The PLC and touch panel are the...
19,231
