Honeywell HC900 Profibus Communication Setup
shashi616
Aug 2016
Jamshedpur
34
Hello Everyone!
I am looking for a solution for making successful Profibus Communication between ABB 800XA & HOneywell HC90.
I had gone through HC 900 CAtalogue which suggests to go for Prosoft Gateway as Master & converts Profibus to Modbus, however in my case my Master is ABB 800XA & I need to communicate HC900 as a slave to ABB.
All suggestions are welcome.
There are Prosoft gateways that are PROFIBUS masters with Modbus RTU/ASCII ports that can be either Modbus master or slave. They also have PROFIBUS slave gateways with the same Modbus functionality. Also PROFIBUS master or slave gateways that support Modbus TCP client and server.
Thanks for you response!
I am not able to find Slave Profibus Gateway, not sure if it exists.
Can you provide the part no of that if you had used it earlier in any application.
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
370
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
636
Does anyone have experience with setting up a HC900 to a prosoft card? Using this to communicate with an Allen Bradley plc
700
Greetings! I'm trying to connect HC900 to Kepserver in Plant via HC900 ethernet driver provided by Kepserver. I put the IP address and most of...
1,120
Hello All, I have problem with Honeywell HC900 C50 CPU, the problem is my all local IOs cards not communicate with CPU. I attached a picture of...
1,664
