Profibus to Ethernet
nirmitpanchal
May 2011
mumbai
There are 4 DCS on profibus...
I need to take total 1100 real data points from them for centralized monitoring purpose using Rockwell PLC or/and SCADA over Ethernet...
Is there any way to get this done????
As MK mentioned you will want to consider OPC, more specifically an OPC server such as Kepware.
Based on the limited information you have provided, you have two protocols - Profibus and Allen Bradley. They would be connected through your Ethernet connection and communicate to a PC through KepserverEX. More information is available through our web site for which both protocols can operate in a single OPC server, simultaneously.
http://www.eternity-sales.com/Kepware/kepserverex.htm
Should you require more information or are seeking a quote, you can contact me directly via pm or by email below.
If you are in need of Ethernet switches, we also provide those through our relationship with Westermo. More information can be viewed through the link provided...
http://www.eternity-sales.com/Westermo/industrialethernet.htm
Disclosure - ESI is an authorized distributor for Kepware and Westermo.
I apologize if this is the wrong forum to post this in. I am looking at upgrading some older PCs that are using Siemens CP5613 cards and was...
1,703
Hi guys, One of the remote (pump station) PLCs I'm replacing in a water project has an existing Profibus connection and the client wants us to be...
4,824
I am working on converting from a seimens micromaster 440 communicating by profibus to a Schneider Electric altivar 71 communicating over...
1,201
Hi All, I looking for easy solution for my task. My customer want to collect all scada visualisations to one PC. There are six PLC's(Siemens...
1,226
Hello all, I am hopeing someone on here can help me. We currently have our plcs connected to an ethernet network, connected to this is a desktop...
4,291
