Proficy cannot go online with CPE305
Let me make sure I understand what you're working with. You have a PC (192.168.0.???), a PLC (192.168.0.100) and an HMI (192.168.0.101).
They are all connected through a switch???
The PC at 192.168.0.??? can download a program to the HMI at 192.168.0.101
The PC at 192.168.0.??? can not establish a connection with the PLC at 192.168.0.100, nor can it ping IP address 192.168.0.100.
Can the HMI at 192.168.0.101 communicate with the PLC at 192.168.0.100???
That is the way I see it too.
I would agree with Steve's post # 7 to try a command line "arp -d" and reset the table.
Except I have never heard of "Set Temporary IP Address" causing the need for this?
Alright fellas, this has been an interesting day and a bit of a learning experience. Though the actual solution is not quite clear to me, everything is now working as it should.
I enlisted the help of one of our network admins to run a series of system updates that I had neglected. He also changed the setting on my Windows 7 Virtual desktop's Network Adapter to allow it to share the hosts IP address (also Windows 7 pro).
It looks like it was a PC issue all along.
Thanks again for the continuous support!
Hi all, I have a project that is giving me some issues. I was experimenting with using the TOTALIZE function block in a project, and it never...
2,041
When attempting to upload the hardware configuration I get the message everything was uploaded succesfully but in the message center I get this...
1,764
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
53
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
109
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
105
