Proficy ME UDFB
mondi
Sep 2009
Utah
Good Day. I have been pulling my hair out for 2 days trying to figure out PME's use of UDFB. I am proficent in AB and Modicon and created many a UDFB. Can someone explain to me how the UDFB is used in PME. For instance, I create a function block with parameters such as a discrete alarm that has an enable bit, alarm delay, reset, etc. I then "bring" that function block into a ladder, or whichever. The first thing the PME wants is an instance. So we'll call it Alm1. Then I have a UDFB called Alm1 and several blank inputs and outputs but a structured data type called Alm1. How does this compare with AB or Modicon. In either of those, you just have a "blank" FB to use and you tie either single elements to the in's/out's or a "structure". I have ready as much as I could find on this. Maybe I'm just too old fashioned and can grasp the concept of Object Oriented Programming.
PLEASE HELP
Thanks,
MA
I Make a Main Block as Pump and Make it Function Block and set the Parameter Run Trip Auto Create a UDT with Tags(Run,Trip,Auto) Now I have to...
1,929
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
121
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
107
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
78
