Profinet to Profibus DP/PA gateway that supports a Profinet ring topology
substrate
Dec 2004
Hi, I'm working on a project right now where my client has an existing GE RX3i redundant PLC system, with Profinet communication cards in the racks. They have implemented a Profinet ring to connect the racks and remote I/O, and we'd like to add a Profinet-to-Profibus DP/PA gateway onto the Profinet ring to talk to a few PA instruments.
1. Can anyone advise of a Profinet-to-Profibus DP/PA gateway that support the ring topology on the Ethernet side? This would require that the gateway has two Ethernet ports.
2. We won't have any instruments on the DP network (only on the PA network). Is there a gateway that converts Profinet to Profibus PA directly (without the need for, say, a DP to PA link module).
Thank you for your time,
Brian
Hello automation experts, I know that Profibus was preferred communication much before Industrial Ethernet (Profinet), at least with Siemens. I...
2,003
Is there any way to get diagnostics info on device connected over Profinet/Profibus (communication with device fault) from PIW assigned to that...
2,489
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,291
I'm more familiar with Rockwell than I am Siemens - as this question I'm sure will demonstrate. For Ethernet/IP and ControlNet networks, there...
1,808
Hello I am currently looking into converting our PLC profibus setup, with Siemens S7-300 CPU 313C and IM-153 interface modules to other cabinets...
1,718
