Conversion of profibus to profinet
Ljohansen
May 2015
Odense
Hello
I am currently looking into converting our PLC profibus setup, with Siemens S7-300 CPU 313C and IM-153 interface modules to other cabinets.
I want to chance to an profinet setup. Witch models do you suggest I look into?
Anything else I should be aware of with this conversion?
Thanks o_O
It depends how much you're looking to change your system. I'm a fan of the new 1500 (all CPU's have PN built in), but it might involve a lot of re-work to take advantage of some of the new features. If you switch to a 314C-2PN/DP (6ES73146EH040AB0), then the engineering changes would probably be minimal. You could also buy a CP343-1 and add it to the 313C you are used to using, but that solution isn't as straightforward as upgrading to a PN cpu.
I like working with Profinet compared to Profibus. It gives you more flexibility for how the network is laid out, and I seem to be spending less time troubleshooting the physical network. Instead of assigning a profibus address to a device, often via physical DIP switches, you now assign a profinet Device Name. This can be done either via the engineering software or with separate stand-alone programs.
Profinet is also nice because you don't need a Profibus converter dongle anymore, you can connect to everything via Ethernet, which laptops already have. The main "trick" is that you typically need to assign a static IP address to your laptop that is in the same network range as the devices to which you will be connecting.
The Primary Setup Tool (PST) is a great tool that allows you to browse the Profinet network to see what devices are there. It can assign both an IP address and device name to each of them, and many can also be reset to factory defaults.
https://support.industry.siemens.com/cs/us/en/view/19440762
Hi Need your guidance once again. In one of our system , one temperature measurment device is communicating with siemens S7 PLC. The temp...
2,416
Well, I'm trying to change the profibus to abdh( data highway) on a ctc hmi screen. I'm using machineshop software. Their tutorials or examples...
2,843
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
124
