Program Conversion from Delta to Siemens
RockyNivas
Mar 2019
United Kingdom
57
Hi All,
I'd like to inquire about the possibility of converting a program currently used on Delta PLC to be compatible with Siemens PLC using step 7 ? Please advise and Thanks in Advance.
Delta PLC : AS228R (ISPSOFT Software)
SIEMENS : S71215FC
Porting the ladder logic rungs and instructions is the easy part.
I would estimate something like 5-15minutes per rung on average; basic rungs would be ported in a minute or so, but in that longer estimate I include related tasks like creating tags and I/O, complex instructions (PIDs, comms, etc.), writing comments, review, validation, testing, debugging, etc.
Then there is the hardware side. Do the two systems have the same electrical specs for power and I/O (24VDC? 240VAC?)?
Is there an HMI?
Is there any external communication or fieldbus (Modbus, etc.)?
Are you asking to hire someone to do the port?
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
948
Has anyone taken a SLC500 program and converted it to an Automation Direct Click PLC program? I searched but didn't find anything.
1,779
Hi all, Normally I would try to research this more before asking this, but I am under a tight schedule of changing computers. I have a bunch of...
1,429
Hello I have to convert a MELSEC-A Mitsubishi program which works under DOS to Studio 5000 Allen Bradley. What is your opinion is it possible?
2,127
Does anyone have any experience with converting a Beckhoff (codesys) program to a mitisbushi program? Excluding IO of course. Are both on the...
4,029
