Conversion MELSEC-A program to Studio 5000
MichaelKon
May 2018
Hadera
Hello
I have to convert a MELSEC-A Mitsubishi program which works under DOS to Studio 5000 Allen Bradley. What is your opinion is it possible?
The only way is to do it manually as far as I know.
Have you got a printout, if not it may be possible if you have the original file to post it here & maybe someone could print it out for you.
I was suspecting the same thing, if there's a printout it should be fairly simple (not necessarily easy, depending on the program). I've done this with a SLC 100 upgrade, working from a printout of a DOS program to build the new PLC program.
It probably won't interest you but Mitsubishi have an A to Q conversion tool that's pretty good, in actual fact there is a lot of documentation about using existing I/O with the Q or the direct replacements etc. there is a caveat however, there could possibly be an odd instruction that cannot be converted (rare but possible), here it creates some code using some bits in the higher range (cannot remember the exact ones but that you would need to look at & find a way to re-produce the code.
HAs anyone converted the melsec files to GX Developer files from inside GX Developer? GX has an import function but when I use it I get an A/FX...
3,950
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
119
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
104
