fhervrylesestoso
Good Day Guys
I recently created a program, ( simple program) with Proficy machine edition. all configurations and module configuration (rs232 port settings,I/O,CPU) were met according to required settings)
connections are good , I can go online, but when i try to download the program, I get stuck at "DOWNLOADING REF MEMORY ALOC".. then an error of failed to connect with the device occured. "error 0867".
Why is that so? I try to update it by firmware but it failed (twice). I research for error codes. clear the fault tables and checked the COM port
THANK YOU VERY MUCH GUYS!!
