Program: Please help
jamalshahid
Apr 2011
Tennessee
153
What i understood from this program
PB_start_stop is a momentry push button
In first rung when we push start/stop there will be a rising edge of signal because of DIFU. After first scan motor starts( As we are using Keep instruction so we don't need to hold the button). Motor output coil has logic 1 means it has closed circuit and it is running.
my question is why we have used stop motor (200.01) in second rung?
third Rung flies off my head. Please explain. thanks
Well, right there is your single button start/stop (or toggle, or alternate, or flip-flop or whatever else you want to call it) logic.
The first press, the DIFU one shot triggers. Second rung doesn't generate a stop command, as the coil isn't energized. The third rung however does energize the coil, and seals in around the one shot.
Now the motor is running. If you press the input button again, you get another one-shot pulse. In this case, the one shot pulse can energize the stop_motor output for one scan in the second rung. In the third rung, the seal-in is broken by the stop motor coil toggling, dropping out the run.
Sir thanks for your reply but i did not understand what you have explained. Please explain me in steps.
means in second rung first instruction start motor is keep instruction right what this is doing?
What motor output coil in second rung is doing? and so on...
I was going to write an answer to your question, then I noticed that you are the same person that Ron is answering using his videos as a tutorial.
Please refrain from starting multiple threads about similar topics and focus on 1 thread at a time. Focus on the simple threads/questions first (this uses One-shot which can be confusing without a full grasp on ladder fundermentals). When that is answered, then move to the next more complex one.
I don't want to sound like a jerk, but Ron puts in alot of time and effort on this forum, so please show him the respect he deserves and follow his advice
Sir i can not upload hmi program into pc Mitshubishi HMI model no- GS2107-WTBD Mitshubishi PLc - FX3G-24M HMI software- GT Designer3 GOT2000...
6,329
Sir i can not upload program from hmi to pc please help me Mitshubishi HMI Model no.- GS2107-WTBD I Have Software- GT Designer3 GOT 2000 PLC-...
2,219
Hi, I am new to PLC's and I have a program that I need a little help with an explanation of how it runs line by line. I understand the overview...
30
6,958
Am Student And Am Making My First Steps In PLC World & I Need A Little Help,I Attatched The Ladder Of A Simle Program It's Function To Count The...
4,839
| | | In1 Ls2 Out1 | |-| |---| |---O---| | | | Ls1 Ls3 Out2 | |-| |---|/|---O---| | | | Ls2 Out1 | |-|/|---------O---| | |...
21
9,189
