Programing thermocouple "J" with RSLOGIX 500
Oct 2005
La Paz
I'm a beginner using this and i connot configure the correct scale using the I/O configuration.
The "J" thermocouple works from 0 to 750 ºC.
I would really apreciate an example.
Thanks.
Use the setup wizard in Logix500. Click on IO configuration. Select the Thermocouple input module. Click advanced config. Then select configure. Configure the analog input card. The returned temperatures will be I:x.0, I:x.1, I:x.2, I:x.3. The value will be either in whole degree units or 1/10 of a degree units (eg, 1000 is 100.0 degrees) depending on what you pick for the configuration.
Go to www.ab.com. On the left hand side, select publications library -> manual. Enter the part number of your TC module in the search window and download the manuals for the card.
Hello, I have Guard PLC 1600 by Rockwell Automation (it has been obsolete by them but still in the market and works fine). I need know if this...
1,224
I got DL06 AutomationDirect PLC to program with DirectSOFT6. It is a simple machine (40 in and 20 out, all digital), few valves, a simple conveyor...
23
6,891
Please suggest me programing cable for omron plc sysmac model no. Cpm2a
1,128
hi all, I am a PLC beginner.trying to learn how to program on my own at home. I am about to purchase a training kit online and just needed some...
17
5,184
please suguest me the cable names of following urgent 1) programming cable for PLC nexgenie 2000 model 2) PLC nexgenie 1000 model NG16DL
1,318
