Programming an Absolute Encoder
SSeven
Apr 2009
Waterford
I have an absolute encoder, a TRElectronic one to be precise.
I have downloaded the software and bought the "very" expensive adapter and now I need to reconfigure it.
They tech support is virtually non existant , they have been absolutely no help at all. I have three of these encoders and I cannot get them to program at all.
Has anyone ever used them and is there a step I am missing or a trick to getting them to work?
I am using the EPROG32 software and an older serial adapter.
I have been in contact with their customer support over a period of some two months and they have been NO help.
I need to connect this to an AB PLC.
Need more details!
Which expensive adapter?
You can't program the encoder configuration or program the PLC?
What type of output from the encoder; bus, parallel?
The better the question, the better the answer.
PC Adapter Ver3.4 Serial adapter
TR Encoder type CE65M Parallel 25Pin connector x 2
TR Encoder type CE65M Parallel 303 Connector.
I have the pin outs for these ad the serial port is connected.
The problem is that I try to connect and seem to get no response whatsoever. Should I be getting a "Could not connect to an eprog device" every time I try and connect?
I find it hard to believe that all three devices will not connect?
To make it clear the device needs to be programmed so that it "can" communicate correctly with the PLC. I want a binary code output not a gray code output? among other changes. Changing code on the PLC is not an option
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
157
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
261
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
144
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
979
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
100
