Programming HMI via PLC over MPI (S7)
Johnny T
Jul 2003
Fife, Scotland
642
Hi
I have a Siemens 313C-2DP PLC attached to an MP370 touchscreen via MPI. The touchscreen is quite a distance from the PLC (and up some stairs) and being a lazy so-and-so I wondered if it was possible to download to the screen via the MPI connection without having to go to the screen and plug my lead into the programming port on the HMI??
Has anyone achieved this and knows how it can be done? I've heard it is possible but I've no idea how to go about doing it
As always, any help is appreciated
Cheers
JT ;-)
If it's ProTool it shouldn't be a problem, if the HMI and PLC project are integrated. In the ProTool project, select the contoller, and click the Parameters button (I think its parameters). On the screen that opens up, make sure that you have the processor from the project selected. (you will have options to select the parameters yourself, and you should see the 313 processor. Select the processor). Select Download>Preferences from the File menu, and make sure MPI is selected and that the address of the TP is correct and it should download.
I'm assuming that you connect the PC to the PLC through a programming port attached to the processors MPI port?
I think the remote option needs to be checked in the panel communications, otherwise you'll have to manually switch the Screen to transfer mode.
Hi Johnny,
It also works fine in WinCC, assuming the MP370 project is integrated in the S7 project.
Under 'Connections' you have already specified the HMI's DP address (most likely 3); the PLC's MPI address is probably 2. When entering the 'Transfer settings' menu, check the 'Enable routing' option: It will automatically show you the correct routing MPI: 2 -> PROFIBUS: 3. That is, if you've set the PG/PC interface in Simatic Manager to MPI.
Like STL??? mentioned, you have to set the MP to allow remote access, otherwise you would still have to run up & down just to put the MP in transfer mode.
Hey Guys, I am looking to bring some new guys onto my team and I was pondering the idea of doing a basic test just to weed out some peoeple that...
17
2,820
I am trying to reduce the number of values behind the decimal point on the HMI. The values it is reading are "REAL" values from the PLC. I am...
1,110
Good afternoon. I just recently did my first Panelview Plus 1000 programming using Factory Talk View Studio ME. With a little bit of trial and a...
3,002
Hi guys, Please I need a rough estimate or idea rather (in USD) For a PLC Programming and HMI screen design/configuration contract Project of 50...
36
11,092
Looking to find a programming cable to download an already developed Quick Panel application which I have the software for. The hardware is a...
5,067
