Programming Mitsubishi Melsec FX2N ?
Christian_IA
Jul 2012
Randers
Hi all.
I have aquired a Mitsubishi Melsec FX2N-32MR and some extension modules and would like to get some PLC programming experience :)
Even thou I'm an pretty experienced embedded software developer I haven't very much experience with PLC's so I have a couple of questions.
Are there any free or cheap software development tools that I can use instead of buying the rather expensive Mitsubishi GX Developer ?
I also have a FX2N-485-BD extension board, can I connect the pc used for developing the software via this or do I need the serial cable with the round 8-pin PS/2 like plug ?
I haven't got an EEPROM board, do I need that for storing software in the controller ?
Regards
Christian
You can get a demo version here, limited to 1000 steps, that is more than enough to learn with.
"http://meau.com/eprise/main/sites/public/Downloads/-search_results?SType=0&DocType=035&SessionNum=&UserID=&Division=00015&Opt1=Yes&submit1=Search&Family=0001520010&Series=000152001020040"
You don't need the EEPROM to run or store, that is optional for backup.
You will need the SCO9 cable for programming, you may be able to find a schematic somewhere online.
Good Luck,
tommy23t
Does not look like it has a time limit- only steps.
That is a RS432-485 (I think) converter cable. The connector is an 8 pin mini din, but you have to look closely as to the configuration as there are different styles (keys or reliefs in places)
the link doesn't work, I just come to some japanese site :)
can you mail me the software ?
do you know if I can use the rs485 interface I have attached on top of the plc ?
I'm not sure with that demo software, but I think you arn't allowed to upload/dload to/from the plc either.
But you can find SC09 cable copies on ebay very cheaply
Hi Ronnie.
I will look for such cables and eventually see if the demo version has that limitations, but thank you very much for pointing it out for me.
/Christian
Dear all, Hope all will be fine.I am here with a problem. I have to Program and configure the Mitsubishi PLC Melsec FX3U-80M. i am using GX...
4,002
hey all, i'm looking for an elegant way to programm modularly in ladder on mitsubishi q series. the amount of software being developed at the...
6,228
Recently I am play with the mitsubishi PLC Analog card. The card's model is A68AD. The manual provivide the initial programming for the card is...
12,715
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
325
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
280
