Prolinx 5210-DFNT-DNPM
pdsdownunder
Dec 2011
Newcastle
20
Hi All,
I’ve sort of been thrown in the deep in of a commissioning project and one of the areas I have no experience in is a Prolinx 5201-DFNT-DNPM module that needs to be configured to act as gateway between a Compact Logix L33R PLC and a Schneider SEL 311L 6 Relay protection unit.
The protocol of communication is DNP3 which is something else I’ve never worked with!!!
I’ll be mapping information over in the PLC from the SEL 311 unit to registers that the SCADA can read from.
Is there anyone out there who’s used the Prolinx 5201-DFNT-DNPM unit with a Compact Logix PLC and has an example file with PLC setup code as well as the Configuration builder file that’s required to act as a gateway.
Or…is there anyone else who has any file setup that was used in a Prolinx 5201 DNP3 unit that I can maybe use to decipher how the unit should be setup??
And….is there a SEL 311L expert online that may have some guidance advice as to what’s required in setting up a protection unit to talk DNP3 and how to make its status information available to a Prolinx gateway??
Thanks in advance
Hello PLC Forum, I have an AB PLC-5 with a 1785-KE (DH+ to serial) modul. The PLC-5 channel 0 is used for point-to-point connection to HMI. The...
2,971
Hello, New to the forum here, and to the controls industry. I am trying to do the following: Read and Write to a 5204-DFNT-PDPMV1 ProLinx...
1,891
Can you please provide the pin-out diagram for following; which is used for Debugging of Prosoft make Modbus EtherNet TCP/IP module cat...
2,539
Has anyone ever used the New PV with 6.0 to communicate with plc-5/60 RIO? I was told we were to use the Prolinx module. So far NO good. Are we...
2,854
hi, this is my first time to handle this prolinx. can anyone help me how to configure the mapping between the address of AB and the address of...
3,683
