Hello PLC Forum,
I have an AB PLC-5 with a 1785-KE (DH+ to serial) modul. The PLC-5 channel 0 is used for point-to-point connection to HMI. The 1785-KE module is now connected to a Siemens S5 CP. This is for data exchange to a control system and this worked without any problems for years. Now the Siemens S5 should disassembled and the connection should be replaced by an Prolinx Gateway to Modbus TCP Type 5201-MNET-DFCM.
The configuration of the 1785-KE is:
Protocol: Full Duplex
Error check: BCC
Parity: None
Embeded Responses: No
Dublicate Messages: Accept
Handshaking signals: Ignore
Diagnostic command: Execute
BaudRate: 9600
Loc/Rem Addr: Local
DH+ node: 04
Same settings (FullDuplex, BCC, no Parity, 9600Baudrate) in Prolinx Gateway. Prolinx Gateway Station ID is 7.
1785-KE should be Slave, Prolinx-Gateway Master.
Trying this for 3 days now and I have no connection between this two parts.
Do I need a message command in PLC-5 and if yes which one?
Is there anyone outside, wo can help?
Many thanks in advance
cts_user
Error check: BCC
Parity: None
BaudRate: 9600
Loc/Rem Addr: Local
DH+ node: 04
cts_user
